Working on the Trailer
KVH
Where do you put the boat while working on the trailer if you don't have your own slip--and you're solo?
I'm thinking of renting for one month so I can take my time on the trailer bunks.
I can't see hogging a dock space for three hours.
H20Rat
Re: Working on the Trailer
with a little creativity you can do any trailer repairs with the boat still on it! Its relatively easy to replace a bunk, just have to figure out how to lift the boat. (actually don't even need to lift it. Just block it so it can't move, and then let the air out of your trailer tires.)
Frank Acampora
Depends upon the size of the boat--up to about 18 feet you can lay it on the ground behind the trailer. Larger, up to about 24 feet and you can put it on cribbing--one support at each stern chine and one at the front keel. Larger yet and you need to have it lifted.
KVH
Mine is a 20' fiberglass Stratos with the typical hull design. With the motor it weighs about 2800 pounds. I don't think I'd dare try to support it. I can't think of anything I'd trust under it, unless I made something awfully sturdy, and that could take some real time.
Ayuh,.... I work under Trucks weighing 80,000lbs, sittin' on jacks, 'n jackstands....
Wood Blocking will hold up that tiny boat of yer's....
Ya could probably slide it off onto ole tires on yer lawn....
Ole truck tires hold up 20'/ 23' hulls all the time...
H20Rat
that is easy to support and quite light... That exact same method works on boats weighing 10x that...
dwco5051
I slid an 18' I/O off on to tires in the front yard about 30 years ago. An old COX tilt trailer. Did not realize what the coefficient of friction was between fiberglass and rubber. Ended up using a garden sprayer with water and dish soap in a garden sprayer and a come-along to get it back on. Took me about three hours if I remember right. My wife wanted to invite the neighbors and sell tickets since the circus wasn't it town that summer.
fibersport
I hung my 17-6" inboard from my garage ceiling to change out my trailer, I installed some 6" structural channel to my joists and supported those with 4x4 columns. I used a floor jack to lift the tongue as high as I could go then strapped the front lifting eye to the front channel, then I used a chain fall to lift the stern off the trailer. It would have hung there forever if I wanted to, although it was kind of scary to see the boat just floating there. The hull and engine weigh probably around 2400+ I think
