Boat: 2006 Tahoe 215 I/O
Engine: V6 Mercruiser 4.3l TKS
Engine Serial: OW344165
Drive: Alpha I Gen II
Drive Serial: OW591396
I started to notice poor acceleration and excessive blow-by this season.
Worn piston ring(s) the likely culprit.
Dry compression test indicated 180 PSI for all cylinders except #3, which checked in at a mere 50 PSI.
Wet compression test on #3 yielded full 180 PSI compression.
Now pretty confident that a worn piston ring is the culprit.
And now for the part where I ask for help
Service shops won't give me a free estimate for replacing piston rings, even if I bring the boat to them. They wouldn't even give me a ballpark $1k range for the job after I promised I wouldn't hold them to it... come on, it's a pretty standard job when I can give you all the engine info. I'm hoping several people here have had to get this work done by a mechanic and can chime in with how much it cost them, or at least how many hours it took the mechanic so I can estimate the cost myself. My guess would be about $1K give or take a few hundred ($750-1,250)?
I'm only considering a mechanic for time's sake. I always do my own work on my vehicles and boat, but this job would require me to pull the engine and likely cost me the season, as I have never done internal engine work before.
I know I could do it, and do it right, but it would be a major effort.
With that being said, it wouldn't take too much encouragement, verbal and/or liquid, to convince me to do it myself. Hopefully some people here have done this work themselves and can provide the right amount of encouragement/discouragement to help me make my decision.
Here are my thresholds... if I can get it done by a mechanic for about $1k, I'll do that. If it would cost much more than $1k, I'll do it myself and not worry about possibly missing this season.
Thanks in advance for your help. I LOVE this forum!
~ Jesse
~ Jesse
