JSMoore
- Joined
- Sep 5, 2010
- 110
The Setup:
1987 OMC Cobra 4.3
Closed cooling system
Compression Checks in the 170's - all cylinders
Cooling system pressure check - holds 14lb. for 2+ hours.
No leaks in exhaust manifolds
A while back, I opened a thread where I indicated that I had some water in the oil and thought that it might possibly have something to do with the intake manifold gasket. Well, I opened her up to see what I have in there. Oh My! This doesn't look good.....
The intake gasket was in pretty sorry condition, and was virtually destroyed when I removed the manifold. Except for all the spilled milkshake, the inside of the lifter valley is very clean. There are a few traces of NEW rust inside there. But, nothing old. There is, however, a lot of rust on the bottom of the intake manifold, under the carb/choke area.
About the only thing that really seems to stick out is that most of the thick, cheesy, milkshake oil is stuck underneath the intake manifold and in the lifter valley toward the back of the engine.
Please take a look at the pictures and throw some advice at me. I really can't afford to replace the engine right now. But, if that's what it takes, that's what it takes.
Thanks!
JSMoore
1987 OMC Cobra 4.3
Thanks!
JSMoore
