WOT,Decarb???
jpbaker
This is going to sound dumb, :eek: but what is WOT? And Decarb? do you have to take the carb apart and do this?, or do you just squirt a little carb cleaner in the intake to clean it out? :confused: Doc,(or anyone can you help) I'am kind of the new guy here.
jpbaker
Re: WOT,Decarb???
Yup! I was right, feeling pretty dense,big Raspberry for me. :p :p :p How about the<br />Decarb?
roscoe
Re: WOT,Decarb???
Decarb or removing carbon, does not clean the carburator, it cleans the carbon out of the cylinders.<br /><br />Running a fuel additive/stabilizer (SeaFoam) will maintain your carburator<br /><br />Decarb:<br />Your intent is REMOVE the existing carbon buildup from the cylinders, heads, and rings, a spray decarb solvent product, such as SeaFoam DEEP CREEP, is needed to do the decarb process. Some people use one can per cylinder. Free moving rings are what seals your cylinders and gives you compression. Compressed and stuck rings equals loss of compression, and eventually, engine failure.<br /><br />Run engine at fast idle, with engine running, slowly spray liberal amount into each carb, its gonna smoke up the place,<br />spray for a couple minutes, now spray a larger amount into carbs until engine chokes out and stops.<br /><br />Remove spark plugs and spray decarb liberally into each cylinder, install the spark plugs, let it soak for 1 to 6 hours. <br /><br />Start the engine and run at medium throttle, or if at the lake, run it at full throttle. It won't hurt to spray some more through the carbs. Run it for atleast 10 minutes to flush the crud out of your engine. Now remove and clean, or replace the spark plugs. <br /><br />It works well to do the spraying, the night before you go to the lake. This way you can let it soak overnight, and really flush it out at the lake.<br /><br />Don't do this in front of the garage door or the house, unless you want it coated with greasy crud.
jpbaker
Re: WOT,Decarb???
Thanks ROSCO for that info, and the detailed response that helps me alot. I REALLY appreciate<br />the help and information I get and read on this forum. You guys are the best :) :) :)
