Hello, I have a '75 Merc 1500 that is propped to make 5500 RPMs with a 17 P. A little history: I changed the fuel pump diaphragm last year and have both a built in and portable tank that I can use/alternate. My problem is that when the motor gets to about 52-5300 RPMs, it suddenly loses power back to about 4800 and won't respond/maintain that last little bit of throttle. It runs flawlessly otherwise. The power loss happens on both tanks. Assuming this is not a fuel delivery issue, what would be some general things to possibly pinpoint if it's an electrical problem? The timing is set at Max 21 degrees at cranking speed. My main worry was that could this be a symptom of detonation? Any and all replies appreciated, thanks!
