I have a Boston Whaler 160 Dauntless with a Mercury 115 HP Four Stroke. The WOT range is 5800 to 6400. With a Vengeance 15P, I was turning 6300 at WOT, but it was slow to plane. I changed to a Trophy Plus 4 blade 17P and performance improved dramatically. However, the rpm at WOT is now around 5700-5800...right at the bottom of the WOT specification. I have the following questions:
1) How exact is the rpm WOT range, and how much below the specification can you go without engine damage? I know Mercury will say ZERO tolerance, but what are your opinions or experience?
2) I am somewhat confused by the determination of WOT rpm. I assume the standard determination is done by reaching full throttle, then trimming out for maxiumum efficiency to get the number. However, this seems to have a flaw. If the WOT determination assumes no lugging of the engine, WHEN FULLY TRIMMED OUT, what is happening at anything below WOT when the engine is not trimmed? Is it always lugging at lower rpms? It would seem a better measurement would be to reach WOT without any trim, which would be a worse case. On my boat with the Trophy Plus 17P, without any trim, it reaches 5200 rpm, which is clearly lugging badly.
Anyway, I am concerned that I am too close to the WOT spec and do not want to hurt the engine if running at midrange rpms without trimming exactly right. Hope this makes sense. All opinions appreciated.
Mike
Mike
