WOT rpm and top speed?
wilson750
I finally had a chance to take the boat out fishing.. The top speed seems to be very poor..At WOT its at 5200 rpm going 24mph..17p prop, 2 guys 13gal of fuel and some gear!! I dont know the weight of the boat,its not on the title..It is a very heavy 19' cc Its an North American.. Should the top speed be alittle better? I see posts that guys are going 38mph!!
MikDee
Banned
Re: WOT rpm and top speed?
And, how much horsepower are we talking about here? And, Or, what kind of power, outboard, I/O? :confused::confused:
MikDee
Banned
I'd say chances are the rubber hub in your prop is worn out, & spinning, like a slipping clutch, it's no longer grabbing the prop. A simple fix at a prop shop, or get a new prop.
One way to check is:
With the engine off in reverse gear, if you can grab the prop with gloves, and if it turns by hand clockwise on the shaft easily, the hub is shot.
Chris1956
I agree with Mike. You should be seeing about 35MPH at that RPM, unless something is wrong.
wilson750
Thanks guys..I have a new prop on the way because the prop that is on there looks like it went threw a war!! It appears it was bent and somone bent it back!!But I didnt think it would make it go that much slower!! The new prop will be here on thursday!! I will try to turn the prop also!!
Thanks
wilson750
Just tried to turn the prop in reverse, It has alittle bit of play.. Id say about a inch before it will start to turn the motor over!! But I will put the new prop on thursday..
If one of the blades was bent alittle would it make it go that much slower?
