1997 Maxum 1750SR.
New GM 3.0L.
Rebuilt carb.
New Fuel pump and fuel system test.
New EST ignition set. Checked base timing (1' BTDC) multiple times.
14.5x19 prop (OEM was 13.75x21)
Anyone who has kept up with my posts has noticed a trend... constantly chasing a WOT RPM issue. I've been through and through the WOT RPM tips on the site.
The boat runs better than it ever has, however, it still won't reach operating RPM of 4400-4800.
In fact, I'm starting to believe that conflicting Merc info related to carb jetting may be the issue. The jets in my carb (#807504) are 1.55, as the parts manuals suggest. However, the service manual references sizes of 1.60 and 1.65.
Current symptoms are fully trimmed at WOT, I'm only getting about 3600rpm. If anything, the aftermarket prop should be over revving the boat.
However, 3400 rpm is reached somewhere between 1/2 to 3/4 throttle, and going to WOT only gets about 200 more rpm.
It's also worth noting that anything past 3400rpm and the engine begins to sound much different, a good bit of noise, similar to what sounds like an aluminum can rolling around in the exhaust. Because of this, I rarely run anything over around 3/4 throttle, where the noise doesn't exist. Now, this could be the exhaust baffle, although it's new too, so I'm not sure why it would be making the noise.
Also - I've been pulling the plugs and they are as clean as the day they went in. This makes me think I'm running lean. Which leads me back to my theory on the jets. Could having 1.55 jets instead of 1.60 or 1.65 really make nearly 1000rpm difference?
New GM 3.0L.
Rebuilt carb.
