jimmbo
- Joined
- May 24, 2004
- 13,631
If the Manufacturer specifies that an engine has a recommended WOT rpm range of 4500 to 5500 why do some posters on these forums insist on proping the engine to turn 6000+? They drone on and on about overproping, but never about the stresses of overrevving. Since the manufacturer states 4500 is the lower end of the range, anything above that to 5500 should be fine. Correct? Also going a given top speed at WOT, shouldn't an engine that attains that speed in the lower end of the range get better fuel economy than one that is propped for the high end of the range. I ask cause I believe that at WOT an engine turning 4500 rpm is pulling less air in than one turning 5500 rpm, and since fuel is metered proportionaly to the air, less fuel should be burned. In addition, since horsepower drops off on either side of the rated rpm, under propping will result in less horsepower being produced while frictional losses are rapidly rising.
