I have an 89 OMC Seadrive 140 that I am trying to revive after 10 years of sitting. I think I am having fuel supply issues, but I want to also make sure it is not something else.
Before taking her out the first time I put and impeller kit on and I had some issues getting the lower unit back on due to the shift rod moving on me and not lining up with the hole. I was pretty sure I got the shift rod back in the correct location without rotating it a full turn, but now I am starting to wonder.
Since day one (this year), I have never been able to get her to run more that about 4000 RPMs. I am wondering if maybe the shift rod is too low and not allowing me to advance the throttle all the way. Is there a way to check that? I measured the distance of travel that the throttle moves both in and out of gear, and it seems to be roughly the same. Could I also just check to see if the throttle plates open up all the way when i have the throttle pushed all the way forward? I know I can take the lower unit off and check the shift rod height, but I would rather leave that as a last resort since it was such a bear to get back together.
PS - in case you couldn't tell, I am a novice at this (to say the least).
