elwilliams13
- Joined
- Jul 4, 2003
- 137
Got a 1991 evinrude 225 and can only get to 4000 rpm with my boat 1979 mako 235. I was wondering if a decrease in wot timing can limit my rpms this much. It worked fine when I got it. Did the 4 degrees timing method set at 14 because spec is 18 BTDC. Now I am lost. Need some more info. All cylinders spark and compression is even at 85 psi which I was told is normal for my motor. Any help would be appreciated.
