wot
Schmoe
Re: wot
wide open throttle. This is set by the manufacturer and engine specific. Boat engines work a lot harder than car engines, lots of drag. Do not want to exceed the rpm's. It also tells you if you have the right prop size. If you boat can't get up to wot, then prop is pitched too high. If boat runs higher than wot, prop is pitched too low.
Dhadley
Re: wot
Thats if everything is working as it should. If things arent going well its;<br /><br />"Whats On Tap" while we're "Waiting On The" repair/parts/mechanic/weather/tide etc.
