would like some input on engine decisions
ereid74
1983 3.8l omc with stringer...sounds like i have a bad bearing :facepalm: what do you guys suggest I do..i know the 4.3 with a cobra outdrive is a good up grade but is probably pretty costly...3.8l's are pretty common engines so im sure i can find another for decently cheap in a junk yard..or do you guys think that it will be just cheaper to throw new crank/cam bearings in and rebuild the 3.8l? just looking for your guys's input! thank you in advanced!
winterfunguy
Re: would like some input on engine decisions
Quite honestly, unless you are absolutely in love with your boat it won't be worth the money to swap. Consider that you will have thousands of dollars into a swap on a boat that is almost 30 years old is counterproductive. I would recomend just replacing the 3.8 and calling it a day. It will probably be more cost effective to replace the engine vs. Rebuilding the one you have. Just my 2??
ereid74
Alright so i pulled the engine and everything seems to be fine inside? it was knocking deep and wouldn't even idle anymore? how can i check to see if a bearing is starting to go in my stringer outdrive?
