Would this Cause an Overheat?
pbmang
If you look at the exhaust gasket to the right of the water pump, it is melted in two places.
My motor has been overheating on me, and I checked my water pump and everything looked pretty good. Since they are cheap, and I had it apart, I went ahead and replaced it, but also noticed the exhaust gasket being melted. If my water pump is working fine, would this cause an overheat as well?
Here is a picture:
You can see where the gasket has melted in two areas and deformed.
Thanks
Chris
rodbolt
Re: Would this Cause an Overheat?
nope.
but your pump is an ABSOLUTE WASTEOID.
WAY WAY overdue for maint.
take a clean pic of the housing and insert for us.
nice pic by the way.
99yam40
Hopefully you replaced that wear plate also, it is grooved pretty badly
yamaha troubles
My Yamaha 250 ss is overheating. The buzzer went off instantly as I turned on the motor to do another drift. Could it be the Thermostats? Please let me know. Thanks.
bowhuntrrl
Start your own thread !
99yam40
With all of the proper info
