Edited to request you start down at 7th post with the 2 images. You could read this original too I guess.
1989 3.0 liter with stern drive. I took on water at lake and when I got it home I saw the bellows was ripped. So replaced bellows. Took back out to lake put it in at dock, hopped in boat and opened engine cover only to see it taking on water at a pretty high rate. Yes drain plug was in. So remove stern drive and look and see that the gasket was ripped at the bottom. I did a look around with bright flashlight and all bellows looked in place and attached. Would this rip cause it to take on water? And even if yes, it seemed like a pretty high rate of flow for water coming in that little spot. Thoughts?
