Re: Would you be afraid to buy this? added Another!!
Although the ad doesnt say, #1 is actually a 1956, and was the first year Johnson made a 30 hp, and the last one until 1984. It is actually a slightly modified 25 hp which was made for several years prior to 1956. I bought one of the old 30's last fall myself. Paul is correct. The consumable parts are easy to find. However, if you ever need any internal engine parts, availability will be an issue. When you do find them, they will be high. $450 sounds a bit high for this motor. I suspect his reserve would be in the $350-$400 range. This engine comes with a 2-line pressure gas tank which looks to be in good shape. That tank alone sells for $100-$125 on ebay. <br /><br />Dont sweat the 6 v. starter. I took my 6 v. starter to the starter shop for verification of it being 6 v. Tech said it would work just fine on 12 v. but use it with discretion, only 10-15 seconds at a time, with cooling time allowed between crankings. If engine is tuned properly, thats more than enough. The electric choke solenoid is another issue. You might want to find one off a 57 or later which are 12 v.<br /><br />#2, on the other hand, is no older than '84. It will probably be the stronger runner and will get far, far better fuel economy. The older big twins were thirsty. Engine parts will also be easier to find.
