ttankmoran
- Joined
- Mar 22, 2015
- 39
This is the top piston out of my 1966 Evinrude Fisherman. I tore it down because the base gasket failed and was leaking water under the hood. Since nothing has been touched under the hood for 50+ years I decided to freshen things up. Compression test showed 65 PSI on the top cylinder and 75 PSI on the bottom cylinder. Only the top piston is shown in the pictures. The scuffs are are on the transfer port side, exhaust side was fine.
The pictures actually make the scuffs look a little worse than they actually are, you can feel the texture with your finger nail but nothing grabs it.
So what's every one's opinion? Pistons and rings are getting more expensive by the day for these things. Im hoping to get away with a hone and a set of rings, It would probably be fine to re-use but on the other hand if I replaced them there is no reason this engine wouldn't go another 50+ years. Opinions?
