Re: Wrapping plywood with fiberglass
How do you guys get the edges to lay down?
I'm having some trouble with it and would love some tips.
Pics:
That is the bottom of the piece. I'm having issues with the edges mostly.
I'm a total glass newbie, so anything would help.
Thanks guys,
Its real simple flamron .. why you are having the mat "lifting" and air pockets ..
Its not a case of too much resin in your layup..
Its a cause of Improper PREP in your ply edges .. I can Guarantee you did NOT seal those ply edges prior to your lams.
That is why Proper prep on your wood is Paramount before your layups !! ..
It Does not matter if its the Edge or the face of ply that you want to apply Glass and resin.. IF its NOT Prepped correctly your in for trouble ( I keep saying this over and over again ! ) .
Think of a "Suction Cup" .. it works because there is No release of air into the cup from the substrate .. peeps dont use suction cups on CDX or OSB or ACX or Bare Marine ply .. it will not hold there cups. .. you have to make your wood like Glass Before you even think about Layups .. so the glass/resin works the way its intended ..
Mebbe I will do a Iboats ONLY vid for this Cause and affect of Improper prep from different kinds of wood/lam .. Now things are winding down for me .. Ill talk to VT and see what he thinks about that
Its your wood prep plain and simple ..mat will conform to almost any radi ..given the proper prep ..
YD.
