write-up to change the impeller??
Gonefishin95
i tried to find a decent thread about changing the impeller/water pump on my 66' johnson seahorse but i got nothing. does anyone know if there is a thread out there that could help me? or can anyone just give me a step by step of what to do? and finally, once the engine starts running, should water imediatly start coming out, or will it take a few seconds.
...thanks is advance, the motor that will "never run again" is now running so im almost there!!
Bifflefan
Re: write-up to change the impeller??
look on you-tube. theres a ton of them, may not be for your exact motor but close.
Daviet
You might want to think about getting a factory manual, great investment.
DGartzos
Hint: get the manual before you drop the leg!!!
bktheking
My neighbours 64 Big twin 40 takes around 3or 4 seconds after startup to start pumping.
tashasdaddy
you might want to tell us more than this. "my 66' johnson seahorse"
