My boat currently has a Mercruiser 470 with 1.81 ratio and a Mercruiser 48-78122A4 21p 13 3/4" prop. It's a 21' cuddy and loaded weights about 4000 lbs. Getting on to plane in good conditions can take over 15 seconds, slow. At full throttle my rpm's are at 3800 39mph. WOT range for this engine is 3800 to 4200. Any suggestions on a prop to help with getting on plane? I don't care about top speed, I need power to get up and go quicker.
On a side note, I just bought another outdrive that's geared at 1.47 and came with a Mercruiser 48-66452A4 15p approx 15" prop. What would happen if I bolted this up and took it out as is? Is there a prop I can get that will make this gear ratio work with my engine?
Thanks
Thanks
