Re: wrong prop
Less pitch = higher rpm, less speed, better hole shot
More pitch = lower rpm, more speed, less hole shot GENERALLY!!!
The situation exists however, where a 17P may do just the opposite. It may increase speed, keep the same or provide better hole shot, and raise RPM. This happens when a higher pitch prop has put the engine way off its power curve. In other words the engine cannot twist the higher pitch prop at its recommended wide open throttle rpm.
