Yacht Registry
Hoss the Hermit
Is there somewhere on the web where you can punch in the name and home port of a boat and get some info on it? Like owner, size, power? Curious about some of these, can't seem to find much. Like this one:MISTY NEWPORT R.I.
This is what they had for a tender. Those Yamahas are 150 horse
CATransplant
Re: Yacht Registry
For documented vessels, you can go to this site and enter the vessel's name:
http://publicrecords.onlinesearches.com/documented-vessel-database.htm
I tried it with the name "See World". I had never seen that name, but made it up since it sounded like something someone would use. Sure enough, the data showed up, giving the owner's name, address, hailing port, plus details about the vessel.
It also showed every other documented vessel with that name.
Cool beans!
CATransplant
Re: Yacht Registry
For example, here's your example:
vessel name: MISTY
company owner: CARRONADE MARITIME CORP
address: 4653 WORLD FARM RD
OXFORD , MD 21654
Hailing Port: NEWPORT RI
CG number: 686807 callsign:
hull type: Aluminum forward HP: reverse HP:
service type: Recreational selfpower: 1
gross tons: 132.0 net tons: 39.0
length: 82.8 breadth: 21.0 depth: 10.5
year of build: 1985
builder: STEPHENS MARINE INC
Btuvi
Re: Yacht Registry
Hoss, I'm concerned. You did see my apology referencing your apology, did you not?
Hoss the Hermit
Re: Yacht Registry
Yes, Btuvi, saw it and didn't get a chance to apologize for causing you to think that an apology was necessary. I humbly apologize for not acknowledging your apology. Can we call it even now, I'm losing track?
Btuvi
Re: Yacht Registry
Let's go one more round of apologies and then - - but no, you're right. We're good.
