Yachtwin 3hp cracked “tophat” plastic piece in propeller
LargemouthBass21
I’m swapping all the “guts” out of my old bent and broken prop onto a new one. The little black plastic tophat piece has a chunk missing... is this a problem. Also do I have to grease the rubber insert that goes inside the prop?? Thanks in advance
F_R
The part centers and locates the prop on the hub. If it isn't too badly broken and does what it is supposed to do, I suppose it will be OK. Do not grease the rubber ring, but do make sure is isn't rock hard. It's function is to "give" upon impact with a submerged object instead of shearing the drive pin. It will actually hop over a notch on the hub upon hard impact. Grease may make it hop too easily.
LargemouthBass21
Thank you very much sir, you sure know your stuff!! Should I lightly grease the actual prop shaft of the motor?
