Yachtwin Trouble
surfdutch
I have a 6hp Yachtwin engine.<br />When I start it up, it will run for a minute or so then quit on me. <br /><br />Any ideas on what is wrong?<br /> thank you
Fouled Plug
Ensign
Re: Yachtwin Trouble
Is the fuel line and primer bulb in good shape? Tank vented? When it quits running, what does it take to restart it?
G DANE
Try sqeezing primer bulb every 15 secs. Will it continue ?. Are you sure you opened tank vent valve. ( The little fingerscrew )<br />Post back when you know. It could also be fuel pump malfunction.<br /><br />Good luck.
