Lots of folks know about the 'making oil' issue on 4 strokes and if not, you can search this forum for a little light reading.
My problem was that my Yahama was making oil and the dealer changed the low pressure fuel pump which seemed to help a bit. However, oil level continued to rise, therefore, Yahama told them to change thermostat which they did. Oil level continues to rise but not as much.
I talked with Yahama and they said that if the rings are not seated 100% and since 4 strokes run cooler that if your running the engine at 3000 rpms or less, then you will get fuel blow-by thus increasing oil level in crankcase. They said I should de-carb the engine using their YIEC solution which I am waiting on my dealer to get in.
So, I tested this theory as best I could. I've been trolling for White Bass and Stripers and have measured oil level before and after... these trips were idle troll for about 2-3 hours, then I run the boat over 5000 rpms for about 20 minutes or so, put boat up and go home. The oil level rises anywhere 1/16 to 2/16 of an inch. On a test trip, I ran the boat for a good solid hour to hour and 15 minutes at WOT only, no trolling and measure oil level before and after.. no rise in oil level... GOOD!
I'm not going to give up trolling, so at what point does the oil become too dilluted that I should start to worry about proper lubrication and change the oil? Right now, since last oil change the level has risen from halfway pt. on the dipstick to almost full mark on the dipstick. This was about 15 hours of motor time.
Also, here in the south the Yamalube 20W-40 is recommended, but expensive... can I use API SL or SM 10W-40 from Wally world in order to save money on these frequent oil changes? If not, which oil would be your recommendation? By the way, motor is still under warranty until 2014.
Long post, but any info would be appreciated.
Thanks
Thanks
