Yahama O/B Lower Unit Leaking
Ray Loxterman
I have a 2001 130 hp Yahama with less than 5 hours running. It leaked black oil from behind the propeller for a short period of time. Is this normal?
sloopy
Re: Yahama O/B Lower Unit Leaking
Is this a two stroke wih thrue hub exust, its normal!
Down South
This is common with 2-stroke motors. What you are probably seeing is just unburnt 2 cycle oil seeping from the exhaust since it's black in color. To be on the safe side though, I would check the lower unit oil level and the condition of the oil to make sure it doesn't have water in it. It's probably ok but it sure brings peace of mind to be sure.<br /><br />Good luck :)
