Well its all together and it works perfect. SuzukiChopper if you will send me youre e-mail I will send you pics. One thing though. On the bottom of the leg there is a boss that a nut and bolt goes through. It has a strap that goes around the swivel bracket. You wont use the strap on the later swivel bracket but you must grind the boss down or the motor won't be able to go stop to stop when turning. The boss will hit the swivel bracket before the motor reaches the steering stop. I figured that one out after I had it all assembled and had to take the leg back off of the swivel bracket so that I had room to grind the boss down. I can't wait to try it out and see how much difference T&T makes on the performance.<br /><br />Russ In Texas
