Hi all,
just purchased my boat with a 2000 Yamaha 4 stroke carby model with 90 hours on it, (Australian delivered 62Y - L451546T - 50AEHT).
I changed the oils, fuel filter and had the impeller done at the workshop (due to a small leak in a seal). Took it out and find that it starts OK but when accelerating away it will falter and stop "going" around 1500-2000rpm. If the throttle is pushed hard down it will stall. All I can do is move the throttle gently forward and when it starts to miss, let it sort of stabilise after a cough/splutter before pushing the stick further. Once over that it runs fine and responds OK to the throttle. It may or not be relevant, but I did notice if left to idle for too long it seems to miss a bit and start to die so have to lift the manual throttle to just above idle speed to keep it running smoothly. This happens cold or warm. Any ideas on where to start would be appreciated thanks.
