yam 70b problems
frankie
I have a yam 70bhp engine which drops revs after about 10 mins, she runs fine at first but then significantly drops revs for no reason. Can anyone help me to identify the problem. cheers frankie
vanner
Re: yam 70b problems
maybe you are reaching a high tep limit and it is going to get home mode
JB
Ahoy, Frankie
Welcome to iboats. :)
Could be a heat related failure in the ignition, dropping spark to one cylinder. Put her on the muffs and use a hair dryer (NOT a heat gun) to heat up the ignition parts. See if you can reproduce the problem.
Ray Neudecker
jb is likely right on the target. Concentrate on the CDI since they can be an intermittent failure on the 3 cylinders.
frankie
thanks mate i'll try that, boat is coming out of water today to be cleaned so i'll be able to have a good look inside
frankie
dont know if it's intermitent as it happened twice in a row, had to limp home last time thank god ive got a back up. cheers i will look into it
frankie
frankie
hello there mate, can you tell me where i can find the cdi unit as i have looked through the manual and there is no mention of it. i'd be gratefull if you can help.
frankie
