Yamaha 115 (1989) first start - help!
snsime
Hi, you guys were really helpful before when I was thinking of buying this motor, and now I have.<br /><br />I'm about to start it for the first time (never heard it run... ya, I know!)<br /><br />I know the guy we bought it from, and he said it ran great, but he didn't drain the carbs in the fall. Is there anything different I should be doing when starting it? Add a can of seafoam off the hop?<br /><br />It last ran about 7 months ago - should I be putting a little oil down the cylinders before starting?<br /><br />Finally, do I have this right with the control box: After priming the line, I lift up the fast idle level and hold down the autochoke switch while cranking... and then release switch when it fires or keep holding it for a while?<br /><br />Thanks again!<br /><br />-Scott
rodbolt
Re: Yamaha 115 (1989) first start - help!
one it fires up release the keyswitch.<br /> if it does not idle correctly it most likly will need a carb/fuel pump job.<br /> the seaform is not gonna clean the carbs.
