yamaha 115 troubleshooting
nking
04 F115 will not run past 3200rpm's. the longer it runs the worse this problem gets to a point that it wont idle and then becomes hard to start. changed plugs, all filters, VST filter cleaned, checked coils. i am thinking this is an electrical issue that heat may be causing due to the fact that it gets worse once the motor runs.HELP!
99yam40
monitor the fuel pressures
electrical would not slowly bring down RPM
