Yamaha 115hp outboard
etapatai
What kind of prop would you recommend for long straight line rides on a lake. I own a Lund, 1700 Fisherman series boat with a Yamaha 115hp 2-stroke.
rodbolt
Re: Yamaha 115hp outboard
hello<br /> one that will allow the motor to turn about 5600 with a medium load and a full fuel tank.<br /> good luck and keep posting
wtrojan
The best way is to try several props (with different pitch) in conditions described by rodbolt. Before that, make sure the engine height on the transom is correct – make search for posts abut that matter here and on the General OB forum. The prop that allows you to run engine’s max rpm at wide opened throttle will be the ideal one. Obviously you don’t have to run WOT after you choose your prop, that’s just the way to make sure you have the right setup. Once you are all done, going in the 4000-4500rpm range will allow you save the gas.
