I have twin '94 model Yamaha 130s. One of them starts and runs perfect. The other runs fine once you get it started, but is very hard to start. I pulled the carbs and cleaned them--the only build up I found was in the pilot jets, which I cleaned and replaced. After reinstalling the carbs, the motor started as soon as I turned the key--first time it has done that (when cold) since I've had it. I thought I had solved the problem, but one week later I tried again and it was as hard to start as usual. When starting, I always pump the bulb tight, fully choke, and give about 1/4 throttle. I have found this to be the most successful method, although still not good. After starting the first time, it is generally not a problem the rest of the day, only when it sits a few days. Does anyone have any suggestions of anything else I might try?
