Greetings and thankyou in advance.
While fiishing this weekend the alarm went off in the throttle control. turned off engine and cooled off. When restarted I noticed the water pressure would be 0 psi the when increasing rpm pressure would rise until high rpm was reached would loose all water pressure. I would slow down rpm and pressure would increase. All inlets were open. Should the water pressure remain the same regardless of RPM? Another issue(do not know if its related), when increasing throttle engine rpm would increae but boat woould not move faster. Should you be able to rotate prop(with rubber prop washer) with your hand?
Does it sound like a lower unit replacement?
I need help, have tournament in 2 weeks,
Thankyou
Thankyou
