Yamaha 150 ProV? Yay or Nay?
LaqueRatt
Considering purchasing a Crest Liner pro with a Yamaha 150 ProV. Guy seems honest. Says the compression is low at 90 psi per cylinder. I'm just wondering what I could be getting into if the motor turns out to need work. What is a motor like this worth in good condition? Worth rebuilding? I'd likely have to farm a lot of it out as I'm not at all familiar with a motor like this. It's a 4 stroke isn't it?
It is likely a 2 stroke !-----If it was a 4 stroke with 90 PSI compression it might not run.----Or with humor it might not ---" get out of it's own way "-----Farming out a rebuild will be a shocking experience as far as beer tokens are concerned.
LaqueRatt
How much beer we talking about here? 20 cases? 50?
LaqueRatt
Ouch. Is it worth it? What do these usually bring in good running condition? USD or beer units. Your preference. USD/beer exchange rate = $20?
Can do basic disassembly myself and I know a guy.
LaqueRatt
One other question. If this motor turns out to be a turd, can I just toss another motor on and be good or does it have to be a Yamaha? I don't see many Yammys for sale around here.
Have you been able to identify this as a 2 stroke or a 4 stroke by looking at it?
LaqueRatt
I'm not sure. Does this help?
boscoe99
It is a two stroke motor.
Compression ratio on that model is just 5.6/1.
90 psi is not abnormally low.
Local shop near me charges about $2400 for a Yamaha 150 rebuild. About $1600 for a 70
LaqueRatt
I know this is probably a dumb question, but if I wanted to put a different motor on this boat does it have to be a Yamaha? Does every type of engine need it's only brackets and such or do they interchange easily? I really haven't a clue. I'm probably going to end up passing on this boat due to it being in an area I generally stay out of, but would be good to know for future reference.
99yam40
I am sure the bolt hole pattern for mounting outboard motor to a boat have been standardized, so you would not have to drill ne holes to mound a different motor
mounting pattern was standardized in the 80's
LaqueRatt
I was thinking more about the cables. Will they all just hook right up? I was looking at a couple of my tiller motors today and they have like keyholes in them for cables I think. They look about the same too.
Controls and wiring are specific. If you change motor brand, you change controls, cables, and wiring
LaqueRatt
Well that's not what I was hoping to hear, but thanks for clearing that up for me Scott. I suspect though a determined individual with some fabrication skills could make it work maybe? Or is that just more wishful thinking?
boscoe99
It is not an overly large and complicated job to get brand X cables/key switch/engine harness to work with brand Y.
99yam40
very true, but you need to know which color wires do what for the different brand motors.
steering, shifting, and throttle I am not sure of on different brands/makes
