Yamaha 150 troubleshoot ?
Toula
Hi, a bit of a puzzler...turn the key ON, the bendix gear on starter engages flywheel but cannot turn it to start the engine. Checked/validated fully charged/new batteries, all connections appear tight/clean. When I put cables direct to starter from battery the engine starts. Then when moving forward I go to trim the engine cuts out. To summarize; when I connect direct battery to starter the engine starts, however cuts out when I use trim/tilt. Then when engine is off, the tilt/ trim works. So am thinking the starter is good, the tilt/ trim is good...from there on I’m stuck on what to check next to fix this. As always appreciate the counsel.
mike_i
Ensign
Measure the battery voltage with a voltmeter at the battery while cranking the motor. Then measure voltage at the starter while cranking.
