Yamaha 150 TXRC issues
cstew00
I am having issues with my carbed 2004 Yamaha 150 TXRC 2 stroke motor and I am at my wit’s end. I have rebuilt/replaced everything that I can, and am still having the same issues. I will try to keep this short.
The motor cranks and idles, but isn’t what I would call a smooth idle and you can smell raw gas when idling. When you give it throttle to get on plane, it is missing on some cylinders, but then will hit and smooth out and run ok up to around 32-3500 rpm. Once you give the motor full throttle, it will speed up and then will start to bog down until you pull back on the throttle.
Here are the troubleshooting steps and repairs that I have made.
  • All 6 cylinders have great compression. 127 +/- 2 psi on all cylinders.
  • I have rebuilt the carbs with new jets, needles, and gaskets. Readjusted the float bowls. Even made sure to pull welch plugs out to clean and adjust air bleed screws.
  • Replaced all fuel lines above and below deck with new 3/8’s marine grade line
  • New primer bulb
  • New fuel pumps on side of engine
  • All new check valves in the intake and crankcase because over half weren’t functioning
  • New spark plugs gapped correctly.
  • Has fresh gas in it
  • Visually inspected the reed valves, and all look good.
  • Have good strong spark on all cylinders.
I have taken the carbs off many times and even had 2 other people (mechanics) go through them to make sure that they are adjusted correctly to no avail. So I am sure that it is not in the carbs.
Interestingly, while the motor is running in neutral, you can pull the plug wires off of the 3 cylinders on the left side of the motor and there is no change in rpm, but you can see/hear the spark. Also when you pull the plugs out on that side all 3 smell of raw gas and are clean. video of this can be found here:
https://photos.app.goo.gl/AVaFDlcvwjuON0M23
I am hoping that someone can chime in that has some knowledge of this motor and can help me before I give up. I have had this boat for 5 years and never had an issue till now. It’s a pretty low hour motor, not sure how many exactly, but I don’t abuse it and have always kept it maintained.
Thanks in advance.
scoflaw
Ensign
Take this over to Yamaha Outboard Forum, see if you can get Rodbolts attention. He'll have the answer for you.
Sounds like there is an issue with the way wires from CDI are hooked to the coils.----Firing but not at the right time.----Mark the flywheel with TDC for each one and hook up a timing light to see what is going on.
cstew00
CDI has never been unplugged, so no way that they are wrong as the motor ran fine last year.
scoflaw
Ensign
I see you made it over there, keep posting till you get Rodbolts attention. Usually early mornings and weekends, Smartest guy over there by far.
