Check with the dealers in the Caribbean and overseas, for a parts catalog, and users manual" were all one love here",you can get anything in a day.
We think alike, what if something breaks, I already know which machine shop I'm using when something breaks inside the motor, how sick is that.
Whenever you buy a used motor you want to change the water pump/rubber impeller, drain and fill lower unit with 100% marine gear lube, it's tested with 10% water contamination, and it still easily passes. Put the thermostat in a pan of cold water heat it up slowly what temp does it open? Change all on engine fuel filter,add a 10 micron spin on water separating filter 6 bucks,pour it out at the end of boating season light it on fire to burn it up grease the rubber gasket spin it back on. grease all grease fittings, drain the carb bowls float switchs ok, put the largest drill bit in the idle jet to gently clean it out
