Yamaha (1999) 70hp 2 stroke alarm before starting motor
gregs4106
I have a 1999 Yamaha 70hp 2 stroke on a smaller RIB. One day I went to take it out and even before I started it, at the initial key turn, I had an alarm.
.... I read posts and have disconnected the oil alarm connection (square plastic connector) and replaced the thermostat sensor. ... no joy
Still have alarm going off even before I start the motor... disconnected thermostat.. still have alarm...
when I do start it, it appears to be in limp mode and won't let me raise the rpms.. that's why I thought the motor believed it was overheating (thermostat).. even with thermostat disconnected i get alarm and limp mode
Any ideas??
thanks Greg
mike_i
did you check the level of 2 stroke oil in both tanks?
99yam40
stat does not send a signal, but a temperature switch or sensor does
