Yamaha 2 cyl 50 hp 2002 50TRLA gas in exhaust
dos equise
bottom plug wet good compression have replaced plugs and rebuilt carbs all plugs getting spark still not running right any ideas? i hope its not a power pack Thanks for your help
99yam40
That or inspect to see what all is needed to fix it.
gaskets,diaphragm, check valves.
new pump gives you everything but may need to also get a gasket for where it mounts to the block if it does not come with the pump
dos equise
Replaced 16 yr old fuel pump runs great wholeshot like never since i have had it no fuel leak... thanks 99yam40
