Re: Yamaha 200. Anything I should know?
how often do you change water pumps,t-stats and poppit valve grommets, the book says 200 hours OR yearly whichever occurs first.
most folks that NEED a water pump usually NEED a piston as well.
but yes preventative maint is always better and cheaper than corrective maint.
Water pump kit should be changed every season in the spring. Especially if you use the boat a lot, which hopefully we all do. Some manufacturers will say you can get two or three seasons out of an impeller but I wouldn't risk it.
Thermostats should last a few seasons I think.
As far as flushing the motor with fresh water, all the teachers I've spoken to say this doesn't really do a thing for the motor in the long run. My friend's brother has a ten year old Yamaha outboard that stays in salt all season long. It has to have over 750 hours on it at least, probably close to 1,000. It has been running great since day one.
The bottom line with boats and motors is that if you use them regularly and maintain them properly, they should last a long, long time. Motors that overheat have not been maintained, water jackets are dirty, gaskets are bad, T-stats are corroded, pumps are not changed, oil/gas mixture is off, stoichiometric ratio is way off. This is all part of periodic maintenance whether it be seasonal, bi-seasonal, whatever.
I just put an '87 Yami 200 on my MFG and so far it runs great. I got it used for a good price and the previous owner maintained it well. I'm not worried at all.
