njohnson1960
- Joined
- Sep 24, 2007
- 10
I have a yamaha 115 2 stroke engine. I have replaced the prop three times thinking I had a bad prop running 13 x 19K prop which is original one outfitted when I bought boat 3 years ago. Engine only has 100 hours on it. My problem is when I am at about 2800 RPM I get forward movement as soon as I try to get up on plane and increase throttle The transom seems to sink down and the bow rises up and I Don't get thrust forward then the RPM's climb way too high without much forward movement. If I equate this sound to a car it sound like the transmission is slipping out of gear and into neutral with the gas pedal applied. HELP anyone, is my lower unit screwed up? I dod not hit anything to the best of my knowledge.
