For the first time, I ran my engine on the muffs (I usually only flush it using the attachment). At start up and idle, it sounds fine, but when I shift it into forward -or- reverse at the idle position, I hear a clunking sound, kind of like there is "play" in the transmission or gears, I can also feel it when I touch the engine. However, once I begin to accelerate, it goes away.
Is it that there is no pressure being applied because it is out of the water? And when I increase the RPM's, it is spinning fast enough to eliminate the play?....hope this is normal...thanks.
