Re: YAMAHA 2003 115 4 stroke Power Loss
Did you get it fixed?
Seems you have a fuel related problem.
I very recently had a similar running issue as you.
Idled fine but would bog on acceleration.
All filters were clean.
I hear so much about the VST(vapor separating tank) needing periodic servicing(cleaning).
Removed the intake system to access the VST and found it to be clean(dealer had it apart 3 years ago trying to track down a running issue)
Removed the fuel rail and found two of the four seals on the injectors deteriorated.
One was definitely leaking!
Ordered new injector seal kits @$12.00 x4, Put it back together and it runs better than ever... I should have checked the injectors first!
I think that it was slowly running worse but the EFI does such a good job that I wasn't aware that I had a problem
Since your motor is close in age as mine, this could be what is going on.
It's worth a look to check your injectors. It's not very hard to remove and reinstall.
The VST? Now that's another story
The VST is on the lower part in this picture
By the way. I have the Mercury 115 4S with a Yamaha powerhead.
Please post back if this ends up being your problem
Good luck with it, Scott
