Re: Yamaha 200HP, No Power
It was the carbs!
I removed and dismantled all three carburators and two of them had blocked or partially blocked "pilot" jets. Other than that the carbs looked pretty clean for a 10 year old motor. Carb kits are ordered but had not arrived so I had to reuse the existing gaskets/parts. Now that I have some experience under my belt doing a proper rebuild when the kits arrive should be a piece of cake.
Additional Comments: Compared to the many carburators I have rebuilt in my youth these are extremely simple devices; no accelerator pumps, automatic chokes, etc. The fuel delivery system is also uncomplicated: Two fuel pumps which "suck" the fuel through a filter bowl and fuel lines from the tank. The previous problem has now been eliminated and the motor also starts and idles much better than before. I have reset the pilot screws to 1 1/4 turns. My final question is this: Is there a technique for fine tuning the idle adjustment screws? .. or should I leave well enough alone since it seems to be running fine?
