Re: Yamaha 25 FS Problems
Pull the hood off the engine and take a close look at the throttle linkage and see if anything is loose or you have excess play somewhere due to something that is worn. Can you move the carb butterfiles back and forth against the linkage? Is the throttle link to the igntion timing correct?
