Captaincrisp
- Joined
- May 28, 2016
- 128
All the local shops are all booked up for the next while. I have a 1992 txrq 250 hp 2 stroke carbed yamaha. It will idle for 30 seconds to 1 min cold happly Then shakes ( maybe misses) somtimes then dies. It will keep it running above 1200-1400. After its warm it will fire right up again then die in 2-4 seconds. So ive changed plugs (old ones were fairly fuel soaked and carboned nothing crazy though). Then found a leaking fuel pump while testing them. same pumps as ox66 low pressure fuel pumps. Cleaned water seperator on boat and on motor. Also now im running it off of a clean portable tank and new primer bulb. I dont know where too look next. Im thinking of changing thermostats although i doupt thats it. Any ideas would be really apprecated. I need you guys!!!
