I picked up a new used Pursuit 2470 with a Yamaha 250 OX66 99'. The engine SN# is 61AX102114U with 250 hours. Owner used Ring free and Yamalube which I too have used for 1st season. Put 60 hours on engine last year. ISSUE - At times I experienced a loss of RPM when I went WOT quickly....esp, when the engine was not running for a long time previously. Normal RPM is about 5600 RPM. When you Hole-shot or jump on trottle from low RPM..it hits about 5300 ..and then cuts down to 4200 to 4500 and seems to alternate. I can then back off throtle for a few secs and then "slowly" go up to WOT and it will run at 5600 for hours. I have never had any other RPM issues...rough seas etc. My secret was a "slow" transition to WOT which works everytime.
Also, I have noticed that at lower RPM & Idle that the engine seems "smokey" (from what I've read) a little more than what it should? I've adjusted the Oil Linkage rod ....but still need to cutoff/shorten steel rod to fully adjust to recommendations.
