Yamaha 2S 90 hp oil leak
ed72vette
How do you keep the oil tank form leaking out of the oil level sensor cap? I used a plastic tie to secure it, but am not sure it will work. Is there some type of clamp that goes around the cap?
99yam40
Re: Yamaha 2S 90 hp oil leak
once started leaking it is best to just pick up a new one
ed72vette
Is the cap replaceable or do you have to replace the whole sensor?
boscoe99
The cap is integral with the sensor.
A plastic tie will most times work. Try and get the kind has the connecting end curved somewhat. Also, two thin tie straps sometimes will work better than one wider tie. Space the connection points 180 degrees from each other.
If tie straps don't work then sometimes heat shrinkable tape will do the job. Wrap the cap with several turns of tape and then heat it gently with a hot air gun. Don't heat it too much as it might deform the sensor seal and top of the tank.
ed72vette
Thanks for your the help. I just looked for a price on a new sensor, $150, not a good value for a leaky rubber cap. A better sealing device should have been engineered by Yamaha. I will try all of the above fixes first.
Have a Happy Thanksgiving
Ed
rhd47
If you pull low level sensor out of tank I found some small knots on lip where cap goes over it. Dressed down with file @ fixed my leak. Finally
