2004 vz300tlrc , has been overheating on me. She hasnt been peeing very well, so i took apart the nipple and tried to blow out and trash in the line. Still weak on the stream. Tried the obvious impellor which was just fine, but replaced anyway and still getting hot and not peeing good. The top (cyl 1&2 or 5&6 not sure of the order) of the heads will get up to 190-195 deg. that seems a bit high. dont these run at like 160-170?? I am thinking the sensors and electrical aspect if fine and doing what its suppose to, but there is not enough water circulating. shall i try to pull the thermostats and see if that cures? is there any particular hose i can pull and try to blow out any obstruction?
thanks
thanks
